which head bolts
woomer
113
Dec 18, 2006
huntingdon, Pennsylvania
yes ive read everything i could in the forums but no directly .....ive got a 1992 ---6bolt block and im putting a 1993 seven bolt head on it ............i need a direct answer which head bolts do i use the 6 bolt head bolts or the 7 bolt head bolts ....... and yes i know its interchangable but im asking which head bolts to use ...and i cant find anything with a direct answer in the forums ..........please i need a quick respomce on this thank you
Put in the bolts to match the head. 7 bolt head studs or bolts.
Absolutely do not use 7-bolt bolts in a 6-bolt block. You will strip the threads in the block. A 6-bolt block has 12mm threads, and a 7-bolt has 11mm. You use the 6-bolt bolts with a 6-bolt block and drill out the bolt holes in the head with a 1/2" drill bit.
Use 6bolt studs or bolts! They will work with the 1g 7bolt head.
your saying take a drill and 1/2 inch bit and drill entirely through the head ????
You dont need to drill anything!!! The 1g 6bolt and the 1g 7bolt has the same size holes. I put a 7bolt head on my 6bolt block with arp studs and didn't drill anything!
