420A Which Fuel Injectors would be better?
Stop driving your car until you have the proper fuel setup...
Our engines aren't built for boost in the first place, and boosting and beating on it with a half finished fuel set-up will definately NOT add to its life.. I'm surprised you haven't melted a piston yet...
Also, I don't remember but I believe you should have added a return line, since after 95 they stopped coming with them
Good point i assumed that you had a return line because you already had a FMU but you should double check.
Sorry havent been back in a while, working a lot. FCD is ordered and on the way, had gas leak because whoever hooked up the fuel pump used water hose instead of gas resistant line so it broke. Does the FCD come with instructions? Also, where is the return line to/from?
I know Paul has a picture of this and posted it somewhere. I will try to find it unless he beats me to it.
Found it...
http://www.dsmtuners.com/forums/420a-turbo-conversion/339520-95-fmu-install.html post #12
