Which fan is A/C fan.
If you're standing infront of you're car looking into the engine bay it's the fan on the right.
Yea i need to search for it (or if someone has the link they can post it) cause i need the fan on the right(metal housing) to be the main fan because i removed the fan on the left, it was hitting my intercooler pipe(until i can get a slim fan)
New Page
Follow this guide except you dont have to install a toggle switch. Just run a 16 gauge wire from the engine fan relay to the ac fan relay and what will happen is the ac fan will cut on when the engine fan is supposed to come on. In actuality both fans would come on but since you dont have the engine fan, only the ac fan will come on.
OK i decided to plug the a/c fan into the plug for the main fan. When i turn the A/C on the fan comes on for about 10 sec then cuts off. So i was wondering since the main fan comes on with the A/C fan, did i turn the A/C fan into the main fan by plugging it in the main fan plug?
That ac fan is actually on my car because we did not have enough room for the main fan to fit with the 50 trim. All you have to do is put the ac fan in the place of the main fan, it plugs right in and functions just as the main fan, except it is kinda a slim fan. If you have any questions pertaining f\to the fit of it you can pm me becuase it is still on my car and no overheating issues so far.
