Radiator fans: which fan is which?
valon24
Sep 16, 2013
Roseburg, Oregon
I've read through all the radiator fan posts I could find and just need a quick answer cause for some reason it's puzzling me, LOL.
This is for an automatic 99 GS.
Is the slimmer fan the ac condenser fan and the thicker fan the engine one?
Or better yet, which one is on the passenger side and which the driver side?
Thank you so much!!
Both are the stock plastic fans. I wish I had a chance to take pictures. The driver's side is the thicker fan, and the passenger side is the slimmer one. Here's one thing that I noticed, the thicker/driver side fan only has 2 pins in the power connector and 2 wires going to the fan motor, and the slimmer/passenger fan has 4 pins and three wires going to the fan motor.
In my 99 GS relay box, there's only Radiator LO - no high. Whereas the AC has HI and LO.
Wouldn't that mean that the slimmer/passenger side fan is the ac condenser fan? Does the condenser fan usually sit in front of the ac unit?
pretty sure passenger side fan is ac and driver side is radiator fan.
On my 1999 gs it has AC fan 4 wire connector on the passenger side and radiator is 2 wire connector on driver side.
  • Wanted 6 bolt NT water pipe
    • chrisman287
