which 70mm throttle body to get??
If you look closely at the bottom on its opposite as to what our throttle bodies should be. To make it work the IACV and FIAV would have to be on top of the throttle body as opposed to the bottom so i would have to say the top one.
You can get a mustang 75mm throttle body from summit for around 160 i believe. Thats what i run and have pushed it to upwards of 25 psi so far with no leaks and been running it for quite awhile.
I will be going with a 75mm. I dont know why I thought the 70mm was the 3 inch. I would not have even considered the 70mm for those prices but I thought they were 3 inch throttle bodies and they are brand new so I thats why I asked. I will either go with the q45 TB or the mustang. Thanks.
