Where would you set your Hi settings.
Staytuned
1,587
27
Jan 31, 2004
Kingston, ON, Canada
With these mods where would you put your Hi AFC settings? I had another thread about lean problems ...just curious what others have for settings.
T25 set at 17 psi
60mm TB
Buschur UIC pipe with 1G BOV
Greddy 24R FMIC
255 Walbro, AEM FPR set at 43 psi base
lower honey comb removed
Full 3 inch exhaust.
All othere mods listed here: Mods on my car
first think i would do is to put the honeycomb back in. not good for 2g. are u on stock injectors?
without a datalogger i honestly would leave them at zero until i got a datalogger or dsmlink
Here is a log I did this week: 4th gear, settings were 0 from 1000 to 5500 then they were +2. EGT's 925 C at top of 4th. My concern is the low timing from 2400 to 3600 rpm. Car feels slugish untill 5000 rpm.
Rpm Timing
2416 6
2484 4
2624 4
2752 5
2820 5
2996 5
3060 4
3136 4
3304 3
3532 4
3700 5
3900 6
4240 7
4648 8
5032 10
5352 12
5596 14
5660 14
5860 16
6084 18
6212 17
6264 17
6304 18
6400 19
6464 20
6516 20
So I tried adding a little fuel from 2000 to 5000 and now she hits fuel cut. Screw it .....this year is almost done anyway. I have a dyno run planned for next week and I want to get the most out of it I could.
doesn't look to bad. i would add fuel right at 6K. you can probably get your timing to 22 deg or so.
I got it figured out now so that I don't get any knock in the midrange. Part of the problem was a funky MBC that would spike pretty hard......fixed that. Set the boost to 15 psi raised the FP to 47 psi base and added a little fuel across the board on the hi settings. No fuel cut and she pulls good through the midrange. :thumb:
I 'll post pics and a vid hopefully tomorrow of my run on the dyno.
