where to start
jmorri15
63
Mar 6, 2009
Kemp, Texas
well long story with this car. the guy i bought it off of had put in a ton of mods. hks vpc, hks gcc, hks evc, greddy 18g, 550 injectors. but had never taken the time to really set it up right or put in a fuel pump thats able to handle the load the 18g could require. so the car would only boost to like 12lbs and then fuel cutout would happen. so after fixing all the small things on the car that needed to get done. harmonic balancer, new act2600, broken turbo bolts and other things i put in a 255lph pump in and hotwired it. so now the car runs great most of the time. however the problem that was small before because of everything else sucking on the car has become a bigger issue because everything else is good now. im learning on the fly i taught myself how to drop the transmission cause i snapped my clutch fork and didnt feel like paying $550 just to replace a $60 part. so i have no idea how to really figure out cause each problem is new to me. so heres what happens. it will be running great and then i will see the air/fuel drop from green to the red with nothing changing in how im driving. then it will start to run like crap and wont boost. i cant figure it out because i dont have a consistent problem. normally i can run up to 20lbs without any problems however sometimes it will fight boost that high. any clues or where to start?
i have the hks bov that vents to the air. the thing i dont understand is if i had a boost leak wouldnt it happen all the time? do you have any idea how to check the fpr solenoid
If you have a 255 pump you SHOULD get a afpr, but some don't think so. What do you mean by it goes from green to red with the wb02? What actual numbers are you seeing on your wide band? Also, you should be recirculating your bov.
EDIT. Your fpr solenoid is the connector leading to your fpr
