Where to get cam dowel pins?
Dxc545
303
18
Feb 8, 2011
Machias, Washington
Bought some cams off of Craig list with messed up dowel. I got it removed just having a problem finding new cam dowels. Read that they are hardened so I don't want to throw in hardware store stuff. Is there a site that sells these oem and is it possible that all mitsubishi use the same dowel pin?
The part no. is MD158443 and the same part is used on all 4G63 engines. It's an M6x14 dowel pin and yes, it will be hardened. However, that being said, a proper industrial-use dowel pin from a proper industrial supplier will also be hardened.
