Where to Find Cam bolt?
Spln_Hrd
1,707
8
Oct 20, 2003
Hastings, Nebraska
I had a cam bolt rust to sleeve on rear upper control arm and need a replacement bolt. Ive been everywhere locally and no luck. I was told by Napa id have to order entire camber kit.
Thanks for viewing
The good news is you don't need a camber kit.
Bad news is you probably need the control arm and the bolt. You'll need to go to a dealer (local or online) for these.
I have camber kit already installed. I ended up buying bolt and taking it to a machine shop and had it machined with the flat edge, for $3 dollars.
