Where the heck Do I get Center Diff?
Tanro
2,457
96
Jul 22, 2009
Montgomery, Alabama
I have been looking for hours online for a Diff. O'Reillys Advance Autozone Napa Rock Auto Google Forums search.
I have not come up with a single freaking clue on where to buy a Center Differential to into a 4 bolt rear end.
Rear end is on a 91 Eagle Talon TSi AWD. I almost certain it was swapped into the car however. What cars came with the 4 bolt and where the hell do I get a new differential?
Easiest way to check if a 4bolt rearend was swapped in is count the bolts at the end of the axle that connect to the wheel hub.
As said, the center differential is located in the transmission
You can also get it rebuilt. I have no idea how much it would cost but it might be worth not dealling with the hassel.
Not sure what you are asking. Is your center differential shot or the 4 bolt rear?
you are correct about the 4 bolt rear it came from a late 92' thru 94' AWD car.
Those year models came with OEM bigger 4 bolt rear and larger axles.
as to the center differential if you are trying to upgrade it the quaife ATB center diffs. will fit all the awds produced from june 91' thru 99'.
hope the info helps.
Rear End is shot. Sorry I a noob when it comes to anything not RWD. I dont know much about these cars allways wanted one and this was dumped in my lap for free basically been stuggling with with comsetic crap cause I couldnt find a rear end diff for this car anywhere.
Every thing on the car is now fix cept paint and the rear end. I just cant find any around where I live so decided to look online.
