where is the tac wire
nAiFk1e
79
Sep 30, 2009
Mckinney, Texas
i cant find the CORRECT tac wire to use for my remote start. no you cant use off the injectors or whatever, none of those wires work. i have a 98 talon btw and it says on direct techs that its a white wire "somewhere" under the hood or i can use one off the injectors which DOES NOT work :ohdamn:
Tach, White Wire, PCM Driver's Fender Wall
(the tach is white at the power transistor on top of the engine. i dont rememebr if this one is just for the 1g)
i know ive been looking for that thing for a long time now. i actually kinda just gave up and will randomly try and look for it sometimes
i have alldata, i will check and see if i can get you a diagram of where it is. and i will post it up for you.
this is all that alldata shows. hope it helps alittle. by the looks of it. it's near the throttle and cruise control cables.
