Where Is The Coolant Feed/return On The Block?
Foreverfalcon40 said:
Where is the coolant feed and return located on a 2g 7-Bolt block?
For the turbo im taking is what your asking, but the water lines for the turbo is not on the block, one is on the thermostat housing and the other is on the front water pipe.
I dont think that he is asking where the turbo feed and returns are. There are also feed and return lines for the block, just as there are upper and lower radiator hoses - both for feed and return, respectively.
The feed is located on the water pump side, where the coolant gets forced into the motor, and the return is locaed on the left side of the water line, on the front of the block. It connects to the Lower radiator hose.
There acually is coolant line that bolts into the block on the 2g for the turbo, its right on the front of the block. The 1g has a spot on the water pipe to bolt a water line. Then on both cars there is one from the waterneck.
I am sorry for the inaccuracy of my question! I am running a BIG 16G. I know where the feed and return coolant outlets are on the turbo, but now I need to connect them to the block. I on a 2g 7-bolt block, where is the coolant feed and return line located?
So there, is one on the block and one on the waterneck. Which is feed and which one is return?
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
