1G Where is my ECU?
well in order to get it "chipped" you need to figure out wether its eprom or not. now onto how to uninstall your ecu: you need to remove both pieces of carpet from around your center console (the parts near your radio) now on the passenger side youll notice 1 10mm bolt in the middle and on the drivers side there 2 10mm bolts after its loose and you can wiggle it around i found its easier to remove from the passenger side and pull your ecu out. hope that helps ya.
