Resolved Dumb question, where is my ecu located?
Status
Not open for further replies.
Solution
vfaq too? cuz its there
anyways... behind the radio, but you dont have to take out the radio to get to it... take off the side carpets on the center collum and unscrew the three that are attached to the ecu, two on the drivers side one on the passanger...
for the drivers side,... look for a hex screw with a metal tab below it... theres a hole in the silver metal that the tab sticks out of, my old ecu was gold, but my new one was silver...(in color) then the other hex screw directly above it
passanger side,... stick your hand back there and find the box that is standing straight up,... like this if your facing the drivers side in the passanger side: || the screw is located in the upper 1/4 of this box... take it out as much as...
passanger side,... stick your hand back there and find the box that is standing straight up,... like this if your facing the drivers side in the passanger side: || the screw is located in the upper 1/4 of this box... take it out as much as you can, then unhook the harnesses (they each have a button release but you still have to pull hard with the button pressed) remove your ecu...and have a party
Solution
Thank you tstkl, I'm pulling the ucu out and shipping it over to dsmlink. Much appreciated.
Status
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
