Where does a 1G CAS plug into?
SnowBird
527
Jul 9, 2006
Cleveland, Ohio/Tampa, Florida
I have a 90. engines been apart for 2 years, cant find a good picture of where it plugs into, but Im guessing into the plug coming from the battery + side. Its just confusing me because there is a plug on the firewall right there it fits into, but neither plugs have the same color wires in their terminals as the CAS. Please tell me it plugs in on the first plug down from the posotive terminal.
I apologize for a stupid question, I have learned next time when eliminating PS, AC, CRUISE, and EMISSIONS, that it would be very helpful to tape up connectors no longer needed.
It plugs into a connection that should be stuck on the firewall. I can't take a picture tonight, since it's obviously dark. If you don't figure it out by tomorrow I'll snap one and throw it up for ya.
Ok, then I was wrong, thank you.
So, can anyone tell me what the first plug down on the posotive battery terminal side is for? The CAS plugs right into it.
It's on the firewall, right next to the stock battery box location. I believe there's only one that it'll plug into properly. And make sure your CAS isn't 180 off... if you set the engine at TDC, there's a little dot visible through one of the grooves in the end of the intake cam. One side of the little rotating flange on the CAS has a line/groove on it, and goes toward that dot.
Firewall. Found it, thanks.
So what is this other plug it fits into? Its the first plug that comes out from the little fusebox that connects to the battery. Im worried Ill need this, but have no other wires that are unaccounted for.
