Where do these connectors connect?
2qik4u
180
Oct 5, 2007
Free Soil, Michigan
ok so i know im going to go megasquirt. what I have to ask is who can tell me from experience what the #### are the connector that go to the systems or sensors im missing???!!! ive got a connector that is under the intake manifold that is bright green that has nothing that it is pluggen to. and on the same track of wiring I have another plug that isnt connected to anything. it is about one foot or so further down the wiring harness from the green plug. I also need to know what the plug looks like that goes to the second o2 sensor. there is so much unplugged on this motor its noy funny. does anyone have pics of all the harness connections that label what connector goes to what plug???????? i know my o2 sensors srent plugged but this car is haked i dont know what is what!! does anyone have a diagram about what sensor is what on a 420a????????? my system is really really haked!!! any thing would help!!!!
Your question is really "to what do these connectors connect?" not anything to do with actual tuning...
Thread moved and title changed.
Pics please
Pics please (sounds like oil pressure and knock or crank sensor)
It looks like this;
4 wire plug that's in the wiring harness that comes across the top of the engine and down around the cam gear side.
does anyone have pics of all the harness connections that label what connector goes to what plug? i know my o2 sensors srent plugged but this car is haked i dont know what is what!! does anyone have a diagram about what sensor is what on a 420a?
This will help you out a little;
http://www.dsmtuners.com/forums/articles-engine-fuel/100294-2gnt-engine-bay-tutorial.html
and this;
2GNT.com - Acronyms
and this;
2GNT.com - Description_of_the_Stock_MFI_System
and even this;
2GNT.com - Sensor_locations
I suspect that you will also need these at some point;
2GNT.com - PCM_Error_Codes
Also, pics please (of connectors in question)
MB
ok my car is out at my dads house so it will be a week before I can take pictures. When I get pics up I will have like 4 sensors that I dont know where they go. im going to research all the links you guys posted and i will post any progress. thanks for the good info. and thanks paul for making sure this was posted in the right place.!!!!
ok so I cant get out to the car this weekend cause I gotta work all weekend!!! 18 days straight!!! bring on the overtime!! but anyways as soon as I can I will get pics of the sensors and post them. the ecu wiring info is probably going to be all I need to track what sensors they are but i will post the pics anyways cause someone else will have the same question some day!! LOL
