Where can I get this hose?
TurboLaserRS
512
7
May 14, 2011
Dayton, Ohio
One of my boost hoses is just done. It has a pretty decent blowout on the back side of it. I couldn't figure out why my car sounds really screwed up while boosting and I found atleast part of the problem.
Autozone and oreily don't have what I'm looking for. Anything they had would be kinked at this kind of an angle.
Here is a pic of it so you guys can identify what I'm talking about and hopefully have some kind of solution.
Check rockauto.com I've heard people talk about miller import parts look him up. I would just upgrade to a fmic and not worry about rubber hoses again.
+1
You could also go to lowes or Home Depot and get a rubber coupler thy will work, it's only a 45 degree coupler, take the rubber and find one with similar ID
Also if you go the depot way it will hold up just fine I have a friend with a Jetta pushing 582hp running all depot ic pipping.
That's cool, i blew them on the very first pull with a 16g. You can easily find a radiator hose and cut the bend out of it or just buy a 90 degree reinforced coupler with a long leg attached to it.
I found a good price on a 1g upper intercooler pipe setup. From TB down to the side mount. Only problem is that it says it's for ABS equipped cars. My car does not have ABS, will that be a problem? It looks like the only difference is that the pipe is slightly more curved toward the front of the car.
The non abs piping goes closer to the frame rail..The abs piping has to account for the large abs dealy by the battery..
You can use abs piping on a non abs car..:thumb:
I know miller has it..Cause I just had to turn it down from him.
Supporting venders first on this forum of course. However if you cannot find it there quicksilverdiecast is an eBay seller with a ton of new oem parts. Also keep in mind you have a metal intake pipe now, the harder the material this pipe (bov tube) is made of the louder the bov will sound. I only mention this as some prefer loud bov sounds FYI.
