Where can I get an affordable FPR for my 1g?
RandyJr
97
May 15, 2004
Moss Point, Mississippi
Just got my 255 Pump and found out that I need a FPR since it's the high pressure version. A search didn't bring up a lot of results. Oh course I'm trying to keep it as cheap as possible but I would like one with little modifcation to fit. Can I get some names of AFPR's, where to buy them,and how much they cost? Thanks.
High pressure pump doesn't matter a bit - flow is the same at low pressures where it overruns the FPR.
www.fullthrottlespeed.com has a decent unit, otherwise you can get the higher-quality Aeromotive unit from pretty much any racing/performance site, or SX units from www.buschurracing.com. The latter two FPRs require $100 install kits with AN adapters/fittings.
I installed the Full Throttle unit and am having good results with it.
Thanks, that's just what I want, one that can bolt right up to the stock rail. Anyone else have good results with the Fullthrottle unit?
The eBay sold FPR's are decent (OBX) and only require minimal hacking together of home depot parts to make it fit onto the stock FPR flange (some cutting involved)... Total price, $150 with gauge and everything installed...
Do you have any experience with the OBX ones? I don't but I've heard bad stuff about their fpr's. They look nice and are cheap, but if they don't perform then well they're useless. But just curious if you have any experience with em cuz I'm trying to find one to buy right now. And I dunno but OBX isn't a name I've grown to trust.
I am running one personally. It works perfectly, and wasn't a very hard install other than the minor leaking because I didn't use permatex in the first place... Pretty good and cheap part... Of course let's see how long it lasts!
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
