Where can I get a good long block or short block 420a
sadc
274
Feb 17, 2008
Kapolei, Hawaii
Blew my number 4 piston :(. So I was wondering where can I buy online a long or bottom end block? Or should I just build my motor my self. If I were to do it can i get
8:8:1 JE pistons
Eagle rods
and thats about it. Do you think it would be good for 5-10 psi on my t3 garret turbo?
You can run alot more psi than that with what you have listed above providing you have the fuel mods done as well. I have 8-8-1 weisco's pauter rods and stock everything else besides fuel and i'm running 15psi and once i get a better fuel set up i'm going for 20psi plus. It will be cheaper if you could find a used block already set up but i think your better off redoing it yourself cause than you will know what has been done and that it hasnt been beat to hell and back. Hope some of this helps
