where are all the dsm people in Harford/Baltimore county??
Good to hear Adam. Sounds like you're stepping up and gettin 'er done. I'm really glad you broke down and bought an OEM pump. Now you'll be able to sleep at night when you're done with your build. Are you planing on dropping in the engine at your house or up at JSi?
Travis..
I think it is best in some ways to do it here, only because I dont have any wheels, suspension, control arms, ect..on the car and it would be a pain to put this together and then have it towed up there. Believe me I really would like to have a shop like Tony's to drop it in , but then I will have to focus on putting in all the other stuff first and would deture me from doing the main goal, which is putting in the motor! Plus..say I did take it up to JSI, when I have it in, I would have to tow it back because I'm sure with all these parts going in at once, I am going to be idling and driving like crap. The best option I feel is to take it slow, rent a pick, pull it off the stand, and drop it in here. Wire it up here, then crank it up here. I wont feel rushed. How I'm going to do this myself, ????? IDK.
What is up with the shootout guys? We need to figure this out NOW!:thumb:
have any of you found something done by the PO that made you think WTF was this mofo thinking? Today i pulled out the old IC and front bumper off in prep to do my FMIC and i found that someone completly disconected the oil cooler. WTF was going through someones head when they did that? Someone ### gimme a gun. Im going to go hunt down some ppl
Do you have a 90 OFH on the car now? You might have a 91+ OFH on there now and its water cooled instead of oil cooled. If he disconnected the oil cooler and it was still a functional part of the system, he would either of had to loop the lines or plug the M16 X1.5 ports on the 90 OFH. If not, you wouldnt have to take the oil drain plug out cause it would already shot out the OFH..:p So its either a plugged 90 or a 91 style which is watercooled. Your post was a bit difficult to interprit.
Oh..NO GUNS. They resolve nothing quickly.
It does have coolant lines running into it. Id rather have the 90 style with the oil to air cooler. I can sometimes type up some shit that can barly be understood LOL. Guns..No guns.....Ill go get my paintball marker then
I need to find a adapter for this BOV adapter to the 1g BOV
Good luck finding an adapter for that. You may just want to drop the few bucks and get a Tial BOV as it is flanged for that. Tial is what your going to want anyway eventually if your pushing any amount of high boost, though the 1g bov is pretty stout and holds plenty of boost once crushed. The tial flange is larger , so re welding a new 1g flange might not be the best idea. You probably better off getting a peice of piping with the flange already welded and cutting the tial section out and replacing it.
The only problem that i can see is that where that BOV is may not be anywhere i need it. I was thinking of Filling in that flang and making a adapter and have it welded on somewhere where it will be usefule. Also i was thinking of making a custom turbo intake. But thats just me. Ill see what i can do
Hmm where could i? its not a straight pipe it has about 3 or 4 compound bends in it. Ill try to get a better pic of it when i get back home
Been to mandrel bend solutions. Good place. Had them install a magnaflow muffler on my 08 Mustang when i had it. Anyway #### god dam FMIC piping kit doesnt fit for god dam shit "89 90 91 92 93 94 ECLIPSE/TALON FMIC INTERCOOLER PIPING" from Kazespeed ####in BS. I emailed them about it. Ill see what they say. My entire front of my car is off. Some of it is sittin in my bedroom and now this. God dammit:( Thank god its friday and there is a bikini contest and beer tonight
Hopefully when I get this car together, I will be able to get out more.
Update:
I went ahead and got another OEM front case and am going to start to assemble the motor tonight. I'm hoping to have the motor built by this weekend. Though I haven't ever assembled a motor, I think I have done enough research to do it. I need to learn to work on my own stuff right? I am shooting to have it done by this weekend and ready to drop in by next weekend so I can finish the wiring. Wish me luck guys.
Shawn...2 questions for you.
1.) What slave did you use with your TD? I know certain ones are better to use with this than the 1g. Isuzu or 2g? Mine seized up from rust.
2.) After I bleed the lifters and drop them in, can they sit for a week or so, or should I wait until I'm ready to crank the motor to bleed and install.?
I just used a stock 1G slave cylinder. Gave me no problems at all. I have an Isuzu if you want to adapt one to use it. What twin disk are you using?
Also, just wait till you're ready to finish putting your cams in before you bleed the lifters. Are you upgrading to 2G lifters??
Hey....instead of the heartache of trying to figure out how to do all this with your piping, why don't you just purchase a Tial? You're probably spending about what you'd spend on used Tial, anyway.
Im still running stock ecu. the problem isnt the BOV its the piping. Its not fitting the car at all.
The original problem you posted about was the BOV .. why dont you just buy some different size bends and make it yourself..
Like Travis said, 3G big bore. TD is a QM. I've heard the isuzu is best for this TD, but I will use whatever works and costs the least amount of $.
I was going to put the lfters in anyway when I put the cams in , but I kinda want to know if I assemble everything (Cams,lifters,timing bet, ect), how long can she sit? I think they will be OK as long as I get all the oil out of them.
O do not have the tools to do it myself. That's why I got the kit for my car
Honestly your best bet is going to be drive, tow, pull or push your car to Mandrel Bend Solutions and have them make you a custom IC pipe. Their work and labor is well worth the cost. If your shooting for 500 HP or less you'll probably be fine with a modded stock BOV and 2.5" IC piping. They can custom bend and weld your flange to exactly how you want your set up. By doing this you will eliminate a ton of couplers which are chances of one blowing off under boost and each one is another possibly boost leak source. The wait will be worth it if you save up and have a custom one made. Not many people have a shop like MBS near them to do this kind of work for them, we really are pretty lucky. Oh yeah, let me know if you need your car towed out there for a discounted price, that's kinda what i do. :thumb:
I hear ya. If i cannot get this kit installed at all. Ill go head over to MBS and see what theyll charge. I do know there not cheap:(
Make sure you bleed your lifters before you put them in. You'll be fine with them sitting. That stuff can sit there forever, as long as no oil is added. If you do add oil, don't spin the whole rotating assembly, as they'll start to fill up.
This guy is in need of some brotherly love....had a bad weekend and realized its less then 3 weeks to oc car show which i fully intend of taking the talon too and its heart transplant is still sitting. So Travis, Shawn, Adam and Outside the box russ, if anyone had free time coming up text me and let me know so we can get together. I plan on pulling the old one either tomorrow night or wed, but thinking wedensday night is probably going to be it. Anyone plan on going down oc for car show weekend? Maybe we can plan something?
How is sunday looking? Thursday is my birthday, so I'll be haning out with family thurs, and fri. Plan to be hungover on saturday. But those are my plans for the week.
Ill have aiden until about 3 on sunday, so i could do a late afternoon... unless grandmom fights me for watching him which does happen sometimes,, gotta love the grandparents!
Id be down for wrench turnin. Im no noob by anymeans in tearing shit apart and putting it back together.
Happy early Birthday Russ. Hope things are going well so far. Maybe we'll see ya at the shop.
My DSM buddy Matt and I may be able to roll up _____ night after we get off work and hang/lend a hand. You and Adam need to get those sick builds done so you can show it off and hit the strip. EDIT: Wednesday night we can prob roll up there.
Thanks Travis. I almost have all the large parts of my car shipped away, so if anyone wants my shell, speak now. In maybe 3 months, I'll be starting my Mirage project. -gonna do it right this time!
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
  • For sale 420A OEM 2G DSM 420a Fuel Injector Wire Harness
    $15 + shipping/fees PayPal, Zelle, Venmo, Apple pay
    • Stizzydrew
