1G When to upgrade fuel pump?
drcolt
76
12
Jun 27, 2003
Toronto, ON, Canada
What do we look for that tells us we should change our fuel pump out for a better one?
I have link v3, stock internals 4g63t, 16g @15psi, BC cams, 3" turbo back, FIC 750cc in my 88 colt sedan(stock pump fed mpi with two injectors) sized 750 and 1150cc.
I am curious to see how far I can push the stock unit, I have a used walbro 180lph, which I might throw in if need be.
I would like to push the 16g up to 20psi, no more, The traction is already horrible as it is without a good tune.
As stated above you anything over 80% injector duty cycle
Solution walbro 450 HP also suggest you do the pump rewire as well..
You probably need better tires and suspension. My old Laser with s16g had severe traction problems until I bought some Nittos and agxs. It was a totally different car. Still had some wheel spin in 1st/2nd.
