when i'm launching my air/fuel goes lean?
DSMridehigh
Feb 12, 2011
Kalispell, Montana
Car runs fine all guages read good untell i tried launching. i stoped in the middle of the road and reved up to do a launch and my air/fuel guage went lean? :banghead: if any1 has any clue or might know what is wrong please help?
You said Air/Fuel, Does that mean you have one of those gauges that are a light show and not a wideband? If so, disregard the light show and get a real wideband.
His profile says he has a wideband.
OP- can you get a log of when this happens? This would be helpful.
What AFR does it go to?
Unless your saying when actually launch it and are moving and aren't using a Anti lag....
It's perfectly normal for it to go lean while on your on the 2-step it's cutting fuel an the ignition to keep you Rpms where where you want...
You can post a log of launching or holding you Two step to be sure if you would like...
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
