Wheels/Tires for AWD Swap in 89 Mirage
akamiller
37
Nov 15, 2013
Boca Raton, Florida
I'm in the middle of gathering all of the parts for the AWD swap on my 89 Mirage. My car already has the following:
  • KYB AGX up front, GR2 in rear
  • Tenzo R springs (highest spring rate I could find)
  • Front and rear strut tower bars
  • VR4 RS AWD tranny w/viscous coupler eliminator (plan to weld diff)
I'm purchasing the following from Miller Import Parts:
  • 1g Rear driveshaft
  • 1g Complete 4bolt LSD Rear end
  • 1g 23 spline AWD Transfer Case
  • 1g Front Hubs
I'm not a mechanic, but I can handle the the engine and bolt-ons. I'm working with a mechanic/fabricator friend of mine to do the swap. I need help with the suspension and wheels/tires. This car will be a streetable drag car. It is not a daily driver and will be used on the street rarely except for driving to the track or if my daily driver is in the shop for a day. The previous owner did most of the current work. The fenders have already been rolled out a bit. The current set up would cause the fender to eat into the tire when hitting any nice size bumps or dips in the road. I would like to fit 15x8/r15 with 225/50s (Pirelli P Zero Trofeo R). Is this possible or do I need to stick woth 15x7s and a smaller tire? What offset for the 15x8 or 15x7? Also, I think the car will need to be raised a little bit and I'm not sure if that is possible with my current suspension. Any input there is greatly appreciated.
I know there are a lot of posts about wheels/tires/suspension. I have read through many of them. I was hoping more for a just a straight answer of Yes that works, use X offset, and your suspension should be fine.
Link to previous owner's build with pics. http://www.mx5atlanta.com/forums/showthread.php?2079-My-Mirage-of-Dooom-(a-work-in-progress)/page1
Maybe the above was too much to read so I will pull my questions out.
