Wheel related question
LoFall
Jun 6, 2013
Nashville, Tennessee
Ok so I have an 88 dakota and a 97 gsx. Im looking at getting some new wheels for the eclipse, but the wheels on the dakota are warped/bent from being parked in my grandads garage for the better part of its life. So im trying to find out if the wheels on the eclipse will fit right and work with the dakota. I have done a little research, but this is far from my area of expertise. Below are links for bolt patterns and information which I found:
Bolt Pattern for Mitsubishi Eclipse Mk2 | Mitsubishi Eclipse Mk2 Bolt Pattern | Mitsubishi Eclipse Mk2 Bolt Pattern Guide | Mitsubishi Eclipse Mk2 Fitting Guide
Mitsubishi Lug Pattern Reference Guide LugPattern.net
Dodge Bolt Pattern Guide Reference BoltPatternGuide.com
Dodge _ Vehicle Bolt Pattern Reference
They have the same offsets. The hub size is only a few mm off. the studs sizes are different so you may have to get different lugs if you can't use the ones off the truck on the eclipse rims. I'm just crossing numbers from your links , I haven't any experience with this application specifically.
  • Wanted 6 bolt NT water pipe
    • chrisman287
