whats wrong with my crank?
FastGS-T
295
8
Oct 20, 2005
Arab, Alabama
ok i have my head off and like all my pistons are about in the middle of their cylinders, i put my ratchet on the crank pulley and start to turn till i run out of room and then when i let go it falls back as if i never turned it( the crank and pistons fall back to where they were to start with ) i just went down there to turn the crank to get the cylinders in place to time it so i get a full half rotation and then my ratchet starts hitting the frame so i let go to re adjust it and the second i let go it falls back to its previous position...
i have the head off cause i was blowing out blue smoke from the engine ( not exhaust ) and my head gasket wasnt blown but still leaking out oil ( i assume the head bolts stretched because they were not the stock head bolts so someone before me had messed with the head ) so i wanted to get piston 1 to TDC so i could time it ... i thought the pistons were supposed to stay where you put them...???? anyone got any ideas?
is the head still off the car?use an exstension on your rachet to get out past the fender so you can get a full turn on the crank.If the head is on but no timming belt, you might be hitting a valve,you could be hitting compression stroke in one of the cylinders.the main thing is you need full rotation of the crank.
