whats the specs on timming
Timing specs? Base timing should be 5* with a timing light on your crank pulley. You compare the mark on your crank pulley to the indicators on your plastic. timing belt cover. Are you looking for timing specs for your WOT timing curve?
WOT timing curves should have no dips and should start around 10ish and increase from there. Since you are a 1g, you can log knock count. In your case, you want to tune for no knock period.
