timming
4g63tsiawd
310
3
Jan 16, 2004
columbus, Ohio
I just put a timming light on my 90 tsi and I'm reading 28 degrees timming. Why? and if I adj the cas would that f me all up
Im also willing to bet that you did not ground out the timing plug.
I couldn't help but think of this while reading the thread title: TIMMY!!
How does your car run with +28 deg of base timing (rough or normal)? And yes, you do adjust the cas to change the timing back to +5, that wont f you up.
DaveT
92GSX
none taken, although now you can call me timmy I was reading the timming by the cam gears instead of the crank pulley.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
