What to Do first?
91talonjerad
Apr 19, 2009
prestonsburg, Kentucky
I drive a 1991 Eagle Talon 2.0 L 16 valve DOHC. I currently have a aftermarket air filter breather. It is a K&N.
What should i do next?:D
Edit: This is a Non-turbo car.
Make sure your maintenance is up to par! Leave it alone, enjoy the good mpg, and save your money
Lower the compression and turbo the mofo!
ROFL
But in all serious... like said before, take care of maintenance... replace the seals/gaskets/timingbelt/headgasket/etc...
and use brake cleaner on everything to clean up the grease buildup ;)
Just don't turbo it. From my experience if you want a turbo car get a gst or gsx intstead.. too much issues and problems to turbo a n/t =[
Its not as hard to do on 1g's...
As it's been said a million-bajillion times before, make sure your maintenance issues are up to par. Then decide what you want out of your DSM, because as you'll find out, if major power is your goal the NT is not going to suit you. People will chime in and tell you to sell your car and buy a turbo model instead (I swear all this is written in the DSM bible somewhere) If you just want to lightly modify the car as a DD then here's Hideki's suggestions,
You can pick up a decent SS 4-2-1 header and intake off fleabay for cheap, and have a muffler shop make an exhaust system for you. If you still desire more power bigger cams and injectors designed for turbo cars will work (of course that also means you'll need a way to control those bigger injectors) Find a set of struts/shocks and lowering springs (if you can find affordable coilovers do it) and get some slotted rotors, SS brake lines, dual piston calipers and better pads. Do these simple mods, and if you still aren't happy then consider swapping or forced induction.
I think most of the maintenance is up to par other then i need to check the tranny fluids. other then that, it rides smooth and great.
Out of curiosity, how much would an awd eagle talon cost roughly. I currently have a job and saving. Only thing i'm going to do to this car is paint it. As one of your reply said, use my fwd while i work on my awd. i like this idea. now i just need to find a running awd talon tsi and work on it.
also, if you know anywhere close to kentucky that someone has a awd tsi for sale cheap, feel free to contact me and ill see if i can arrange something.
my first awd was a 90 and I got it for $500 and I needed a ECU and Power TR unit...
My 91 was 2k need an ecu and is tore apart right now.
