What solenoid is this?
ninjadave
59
Jan 26, 2012
Port Charlotte, Florida
Hey guys, I saw this part as I was swapping to put another oem intake in and idk what this solenoid does or if I need it. Thanks all.
yep fps. there are about 4 that look exactly like it. theres 2 right next to each other on the fire wall. one in the back left of the engine bay and one in the front left engine bay. just trace the vacuum hoses and see what it hooks up to. the front will go from the turbo to the wastegate, so u know its a boost control, one will go from the manifold to the fuel pressure regulator s its a fuel pressure selonoid, ect.
Yeah I saw the stock boost solenoid on the left. I took all that out because eliminated the egr and canister so I just need a mbc for the turbo and wastegate to hook up correct? And the fps will just attach to the stock fpr and I tee into that for my boost gauge I believe too right? Sorry just trying to get this built motor in the right way the previous owner half did everything in this car.
