What size pistons
motoman358
189
3
Jul 29, 2005
Oak Creek, Wisconsin
I have a 6 bolt that i am rebuilding and i want to run std bore pistons, but i dont want to buy pistons and find out that ill need a bore. I can still see the crosshatching in the cylinders and i cant feel a grove at the top of the cylider (dont know how many miles are on the engine, but was told approx 100,000 but the motor had no mods). i want to use a set of wiseco std bore pistons, do you think that with a hone i will still be within the spec range for the pistons?
It is impossible to tell unless you measure the bore. Take it to a machine shop and ask them if it is within specs.
without exact measurments it is basically impossible to tell where you stand, locally (here at least) a machine shop wouldnt charge shit(definately worth your money and time to double check tho) to check on it for you
It's pretty interesting that you are repeating my answers to people's questions in two threads. Try some originality or remain silent.
What they(first 2 replies) said. One question, why don´t you want std bore? If you are rebuilding, do it right the first time. The pistons cost the same, just a bit extra to machine the block. Be smart and don´t take short cuts were you shouldn´t. Do it right.
