What size is the pcv valve hose for a 92 eagle talon tsi?
You can use a piece of 5/16" or 8mm fuel line hose or silicone hose. Fuel line hose will also be able to resist the corrosive properties of oil.
On a second note you only need like a 4" long piece of it. You can probably get it for free from a hardware store by asking if your really tight on money. Other than free it will cost you less than $1.50 for a 1 foot section of that hose.
Make sure that when you install it you don't make it to long that it will kink and not to short to where it will pop off the PVC or the nipple on the intake manni.
Best of luck to you.
I took the original one to the auto store and they said its a 3/8" so thats what i got :\....3/8 fuel injecton hose is what i found there so i bought it and clamped down each end.
Woops! I was thinking of the hose leading to the intake pipe. Sorry about that!
WOW I should not of replied back because I think I just confused you now. Sorry if I did. The hose I got mixed up is the hose thats on the side of the valve cover facing the passengers side fender. It leads directly to the rubber intake tube between the MAF and the turbo.
The line you got is good. You got the correct one so no worries. I was the one who got it all mixed up LOL.
haha its kool so i did get the correct size then for the pcv valve hose 3/8"?
