What size intake pipe will fit on stock t25 turbo
I believe the t25 intake is about 2", but it has a rubber coupler on it to make it about 2.25" so that your injen intake will fit on it. So basically any intake that ends up being 2.25" should fit or any intake tube that you can put a reducer from what ever size it is to 2.25" will work.
Thanks, I'm gonna buy the Dejon Tool CIP-2gB Intake since it's cheap and it fits stock turbo. When I upgrade the turbo, hopefully w/in the next few months, I'll sell this intake pipe and buy a larger one.
Yes, the inlet itself is actually 2 1/8" but the black ring inside the stock pipe makes it 2.25"
Dont mean to necro an old thread but...i did search and found this thread.
Background:
1998 GSX
I bought a 3" Dejon intake and it came with THREE urethane sleeves that act as a reducer in a very poorly designed fashion. The top one looks as it should going over both the turbo and the intake but is too large to fit the stock turbo so they use TWO smaller sleeves differing in size to make up the difference...only they are the BIGGEST PITA to put on and keep flush.
Question:
Will a 3" to 2" urethane reducer work for my stock turbo for the intake side? I searched to try and find the intake size of the stock turbo but was confused by most of the posts talking about "yes it is 2" but has a black coupler that makes it basically 2.25" I thought it was just 2" on the turbo....
please advise.... Thanks guys
2005 thread. hot damn.
Basically, you stop it. It's 2 inches WITHOUT the black rubber sleeve. I honestly would not waste my money on any intake that size. I would save it AFTER I upgrade the turbo (larger than a 16g) and then buy an intake to match it.
Well i already have the intake anticipating a turbo upgrade eventually...so i just need to know if a 3" to 2" would work for my case....:idontknow:
