what size belt without ac and power steering
34tftf
37
Mar 21, 2011
Chambersburg, Pennsylvania
I got a 7 bolt motor in my 1G and I have removed my A/C and Power Steering and I was wondering if I should go with stock size belts or what I should do. Any help is appreciated, thanks.
The only other accessory belt that exists outside of those two is the alternator belt which runs directly off the crankshaft and also turns the water pump. What you need is an original alternator belt that is 39 inches (original size is 990mm) long; you can find one at any of your local auto part stores.
Am I missing something that complicates this situation any farther than that?
nope i am just making sure before i get to far into my build and mess something up
Why wouldn't you just use a standard alt belt? We have 3 belts, ac/ps+wp/alt+wp... Am I missing something?
  • Wanted 6 bolt NT water pipe
    • chrisman287
