420A What size are the bolts for the transmission?
JR2G
Sep 17, 2015
Houston, Texas
I have a 420a transmission. what are the size bolts of the transmission. Another question since im taking out the transmission just to see if my clutch or transmission got messed since i can't shift to 2, 4 and reverse, do i need a engine mount or can i use the car jack?
You have not been clear about what you mean by size when referring to the bolts on the trans axle.
Which bolts are you referring to specifically?
Are you looking for size, length, and thread pitch?
Are you looking for the correct size socket to remove particular bolts on the trans-axle?
As for removal,review the following link: http://www.mainstreetla.com/transmissionRemoval.php
