Artago
- 2,094
- 31
- Nov 30, 2006
North Vancouver,
BC, Canada
What size AN fitting is this?
I'd say the non push lock personally for high pressure areas but it will still work.Tom, either of those hose end types will work fine. The key is to match the type of hose end to the type of hose being used. IE: You cant run the braided hose with the pushlock hose end...
While there's absolutely nothing wrong with pusk-lock type hose and hose ends, I prefer to use the regular hose ends and braided (nylon or SS) hose.
Jic comes in 2 different angle flares 37 and 45 degrees. An is 37 degrees, so yes as long as you use the jic 37 degree they will fit.
