What should i set my gsx launch at
4 rpm.
Depends on how you use your clutch, how much traction you have, etc. Generally the bigger the turbo and better the traction you will want to make it higher.
ok im running a precision sc44 turbo. I have it at 4500 but to really make it a decent launch i have to slip the clutch a decent amount. ill set it for 5500 see how that works
When I launched my cbr I staged at 75% redline (12000) and as soon as the pro tree went triple yellow I would 75% engage the clutch and go WOT while feathering out the rest. I have yet to get my gs-t to the track but im gonna try the same approach. It def wont be the same as cuttin a 1.40 60' but I will still enjoy the new scenery.... Maybe...
Sent from my SCH-I500 using Tapatalk
depending on clutch, turbo, and how much boost you plan to launch with.
i found on my 16g 1g on stock clutch (only guessing) i did 5000rpm and 5psi. repeated launches even with 15min cooling time between runs at the track, the clutch was starting to feel hot n slippery
4500 rpm should be fine.
You're can't really pick an rpm and ask others where it should be set. You're going to set the launch to an rpm that works best for you and the way you drive or engage your clutch. If it spins the tires too much, lower it. If you bog out, raise it up a bit. Its trial and error. I change mine constantly depending on what tires I'm using, or if I'm at the track vs the street.
I would be interested in the same information. I have yet to drag race my 1G AWD. It has a TRE Stage 2 with a GT3076 in a T3 housing pushing E85.
