2G What should I do with my driveshaft?
Joe Gekko
41
Jul 28, 2015
Kingwood, Texas
I'm pulling the engine and transmission from my '95 TSi AWD, and the car is going to be in that state for a couple of months. It will most likely be in the driveway under a car cover most of the time.
Should I pull the driveshaft, or would I be okay just strapping it to the bottom of the car? It's not about the difficulty of removing it (easy peasy), but more about storage space.
I think it would be best to take it off and store it properly in your garage or whatever, but if space is an issue I feel like you'll be fine leaving it strapped to the bottom of the car. I recommend covering the end of the drive shaft with something, maybe a plastic bag zip tied to it, just to keep it from getting too dirty or scuffed.
Coat the yoke in grease (inside and out) and use a plastic bag if you have to leave it in the car, at least that's what I did.
I've pulled mine a couple times and I leave it in the car. Just put a piece of cardboard down so it doesnt get scuffed. I also spray it with some WD40 and wrap it in plastic wrap then zip tie a ziploc bag over it and I've never had a problem with rust or with it being in the way. Thats how its sitting right now actually Lol
any time i pull something like a drive shaft, I store it either in the car or in my shed.. I also will almost always spray them with a coat of paint.. keeps moisture out and looks much better when it goes back on.
