what pulley is this
my99eclipse
Dec 27, 2010
Williamsburg, Virginia
I have a 420a motor and need to replace the pulley underneath the power steering one. It's the pulley that you use to tighten up the belt. Can anyone give me a link so you can buy the whole set?
has anyone looked at seeing if the idler pulley would fit in that location? you might be able to swap the adjuster screw part over to an idler pulley. idler pulley can be had for much cheaper.
OP, As far as I know the pulley your talking about is the idler pulley. And the bolt is a left hand bolt and impossible to get. Your only affordable choice is to find a 420A car in a junyard and pull it out. The whole assembly could be had for $15. My bolt broke so it was my only choice. Unless you want to pay $120 for a whole new assembly from the dealer. .
