what part needs to go in first
ceth17
87
Feb 23, 2010
lubbock, Texas
I have a 95 awd talon. the parts i need to put in are the fount left and right axle, yoke and transfercase. in witch order do they go in. and my key wont turn any ideas why that is
The yoke first then put the drive shaft in transfer case. Bolt up transfer case. Then put in drivers side axle.Passengers side axle order doesn't matter.
Be sure to put the yoke into the t-case first but the rest is any order you want. As far as your key, if the steering wheel is locked and putting a bunch of pressure on the lock pin, try turning the steering wheel either direction and take the pressure off. Otherwise, your lock cylinder is bad or your trying to start the wrong car.
