what nitto 555r tires fit these rims
starscreem
128
May 2, 2005
hoffman estates, Illinois
hey i was wonding what nitto 555r (drag radials) would fit these rims and what would be the best tire size to put on the back tire. i do have a gst so i want the nt555r tirs on the front
Make: MITSUBISHI Model: ECLIPSE,GS,GSX,GS-T,TURBO 16 INCH 1989-Present Product Number: 24087765
Product Description: 17X7 DP10 G/BLK 5X4.5+42MM GLOSSY BLK
Backside Spacing (in/mm): 5.5/140
Offset: 42 mm
here is a link of the nitto tire sizes they make in the tire i want
http://www.nittotire.com/popup_555r_sizes.asp
just to make things clear i am getting 6 rims 2 i want nt555r tires on and the other 4 will have nt555 tires what will fit my rimes best with no clearince issues. what tire sizes should i go with in bolth i have no clue how to figuer it out
and here is the link to my daily driving tires i want for the rims yes i am ordering 6 rims
http://www.nittotire.com/popup_555_sizes.asp
The only 17" sizes Nitto makes in the 555R that you could possible fit would be 205/40R17 which isn't a choice since it's so small and 245/45R17 which is much to large for that DP10 you are looking at. For drag radials you should go with BFG's, they make a 225/45R17 which will fit that 7" wide wheel(Nitto did make that size but have discontinued it).
