tires for these rims
Evolver
57
Mar 29, 2004
hamtramic, Michigan
what size tires can i fit on these rims. 17x7.0 inch rims +40 offset . and which would give me the best allaround performance for snow dry and wet cause i live in michigan, so i need good allaround tires. thanx
225/45/zr17
I think 235s are not recommended on a 7.0
Whats snow? or Rain? :p
heat and dust I can tell you about
thanx for your quick reply, also does anyone know where i can g3et good allaround tires with those measurements for about 250 dollars?
you are looking at about 100 per tire in that size.
I am in the process of changing over to toyo proxes fz4 (m+S/ softer sidewall) in that size and they are about 125 each.
on an nt yuo can change the front 2, and do the back 2 later...
