what next
1gdsmracer
May 30, 2008
holt, Missouri
so im almost done with my dsm build and i have added a bunch but still havent been able to start it. i need help on the missing pieces. im shooting for 500 hp at the crank. i also want to know my limits on boost and what a stock block can do and all that. any HELP would be great.
mods:
kkk 50 trim turbo t3
punishment racing manifold
punishment racing 02 housing
punishment racing fmic
greddy type rs bov
apexi n1 turbo back
750cc injectors
40mm wastegate
oil cooler
godspeed radiator
ngk plugs
ngk wires
throttle body block off
egr block off
255 fuel pump
arp head studs
cometic mls head gasket
ported head
jdm 6 bolt engine
maft pro with speed density conversion
lm-1 wide band
autometer boost, a/f,water temp
4 bolt rear end
jdm gvr4 5 spd selectable fwd or awd tranny
dss drive shaft
dss front and rear cv shafts
shep stage 4 tranny
I'v seen as much as 500whp made on a stock block. A spot on tune is key though when pushing that much hp on a stock block.
