steel_3d
- 494
- 14
- Jul 3, 2003
LA,
California
I'm getting my head surfaced cause I blew a head gasket (shitty rebuild done before I bought the car), so I'm wondering what other work to do while the head's out anyway. I want to end up with a fun street motor that'll spool a decent sized turbo quick, leaning towards a stroker, but I haven't decided if I wanna do it all now. My goal is a streetable, fun 400whp, 500 max.
Which of these mods should I do since my head is out anyway?
-3 angle valve job, regrind valves, lapping, basically a full rebuild
-1mm oversize valves
-hks 264/272 cams
-adjustable cam gears
-springs
I'm not planning on revving higher than 7500, so the stock springs should be fine. Just wondering if I need the extra safety margin from floating valves once the head's been milled too, plus higher lift cams. The head might've been milled before already, not sure.
What head gasket thickness would be best for copper (sce ics titan): .043, .050 or something else?
The reason I was thinking cam gears is again cam timing that might be off from a changed deck height. Also, I've heard of people improving spool by tweaking cam timing.
If none of these will help with drivability considerably, just top end, then I'll save my money, get the 60 dollar resurfacing done, and spend the money on the bottom end.
Thanks
-hks 264/272 cams
-springs
Thanks
