What MBC is good for at least 25lbs of boost?
Yep. That's the one I'm talking about.
It will hold 25psi. It will also hold +30psi, you just eventually start to lose resolution. A stiffer spring would fix that. I've thought about getting a name brand MBC just for the visual points.
I'm calling you out here as being silly. You have an evo8 ecu in your car so switch to ecu controlled boost. It wont matter as much to you being awd but the traction and being able to tune a boost taper are wonderful. If for nothing else you should go that way so that when someone is running their mouth you can tell them you're running stock boost and then make them cry.
Being able to tell people that I have just pipes, a bov, and an exhaust makes me happy.
