What kind of turbo is it?
mnexcited
39
May 2, 2004
Lino Lakes, Minnesota
Just bought a new car to replace my wrecked one. Trying to figure out what Turbo this is.
Let me know if there is a need for more pics.
Thanks
Nick
I agree with Eclipse 4x4 sure does look like a 20g :thumb:
PS. congrats on the new car
-ADAM-:talon:
Look like a 20g comp cover, but the turbine housing doesn't look like a std mitsu. Check out where the O2 sensor housing is bolted on, looks like their using an adapter plate & the turbine housing itself doesn't look like a Mitsu housing.
It looks just like the Hahn Racecraft Super 20G I used to have. There should be a spacer between the exhaust manifold and the head, and an adapter plate between the manifold and the turbo. The super 20G is actually a T3 inlet, which is why it needs the adapter plate.
the closer I look at it I agree with you.
Thanks, I at least know what I'm working with now. Time to start tuning, just installed AFC and new 620's.
It's all conjecture unless you pull the compressor cover off and measure the wheel.. The Super 16G also had the exact same comp. cover and 10cm turbine housing.
If it is a Super20G, congrats! (the super 16G isn't exactly a slouch either though.)
Neither did I until I swapped out a Super 16G for a Super 20 on a customer car eons ago.
When we first got the turbo from Hahn, we thought that he had accidentally sent a 16. The exterior of the cover is identical and the only outer difference is a slightly larger inlet.
