What kind of suspension bushings???
AWDGreenMachine
82
Mar 16, 2005
Ontario, California
I have a problem with my suspension at 70-80 mph. It feels like the car kinda wiggles... WTF It's hard to explain. The tires aren't slipping or anything but I get this wiggle. I'm assuming since the car is 10 years old, some of the susp. bushings are pretty worn out. What would cause this wiggle in the suspension? Thanks
If your shocks are still good, then it is probably the bushings or you badly need an alignment.
Take a look at you suspension bushings and see if they look old and worn and if they are, then you found your problem.
