What kind of power can a Mighty Max bottom end make?
uummm
65
Feb 27, 2013
Columbus, Ohio
I have a 91 Mighty Max 6 bolt wideblock 4g64 motor. I plan on using a DOHC head on it and putting a turbo on it (this motor is for my RX7 project). My question is how much power can the stock pistons and rods hold up to? I have seen some cars on here with the SOHC motors making good power on a stock bottom end in galants and eclipses but I think the pistons may be different in the truck motor. I'm hoping to make about 300hp for a while, as I plan on replacing the bottom end with forged internals when my budget allows (my ultimate goal is ~500hp eventually), which is still a possibility before I get the car completely together as it is going to be a long project. TIA for any insight.
I got it from a junk yard and they said it was used in their yard truck for a couple years and ran good. at the very least it is going to get a set of bearings and rings and a hone. I have the head off and everything looks to be in great shape.
The pistons will need changed to run the dohc head as it will bump the compression over 10:1 on the stock 64 pistons. Better off running the sohc head until you can get forged internals. Crank will be fine though
What about if I get a cheap set of stock replacement pistons for a galant or eclipse? Would the compression still be too high?
...also the valve reliefs are in different places for the SOHC 4g64 vs a DOHC 4g64 piston.
That and the Mightly Max 4g64 blocks are wider for the RWD trannys vs the trans-mount tranny FWD/AWD motors
So what about using a set of pistons for a 16 valve 4g64 galant? It should put my cr around 9.5, but with a good tune, it should be good for a while at 300hp I would think.
Youre talking about high comp ratio on cast n/t pistons, with boost. While its been done, its most definitely not a good idea. Best idea is to leave the stock 8 valve head on it until youre in a position to get forged internals, that way youre not building the engine twice, and risking the build. Just my $.02
Or find a wideblock 4g63, throw in some oil squirters, turbo 63 pistons, arp hardware, and a dohc head, and youve got an easily 400 hp capable engine on junkyard internals
The problem I'm going to have with the 8 valve head is I'm probably not going to find a turbo manifold for it. It's a good possibility I will just save for the forged pistons, is there any one peticular brand that anyone recommends or are they all just about the same?
