What kind of Fuel Injectors are these ( please view pic )
jajangmyun
Mar 10, 2007
Everett, Washington
Can anybody help confirm identity of these fuel injectors? My guess is Denso 660cc
Also is there a best way to install a different set of injectors w/ new seals, so the new seals dont get damaged?
Nobody answered you question about installation so here you go. Put a light coat of oil or a ral thin film of grease on the seals before install. If you use grease be carefull not to get any on the ends of the injectors. Just smear some around the seal and slide them on.
I would recommend motor oil for this, some grease can cause rubber seals to swell or can make them deteriorate faster.
