What kind of cams are these?
1.37 in on the big side
1.18 on the small side
i got 8.2042 mm lift.
do i have to take in consideration the shim?
both intake and exhaust are the same
I have a set of Delta H272 regrinds, I'll go measure the lobes.
*** EDIT *** My cams (lobes) measure in a 1.109 on the small side and 1.319 on the large. This comes out to .210 lobe height (9.1694mm) I bought the cams directly from Delta (Ken) myself. I'm the original and only owner. My cams are hand marked 272 on both cams (same location where your cams say MT28&29). Hopefully this helps.
Unrelated: I was under the assumption that HKS 272's had 0.397" of lift. Mine only have .361" of lift, wonder if I got the wrong cams? Anyone know if .361" is the lift of an HKS 264 cam?
