What is this sound!?!?! Video included
Nofear20
345
Aug 9, 2007
Yakima, Washington
View the vid please. This sound is totally random. It is squeeky and very annoying. This is one of the rare times it has done it at idle, and I was lucky enough to get a vid of it. It almost always does it when there are any major changes in movements in the car.. for example when i start off from a stop, when I change gears, hit bumps, etc, it will almost always make the sound. I thought it was my J pipe squeeking up against the radiator fan bracket, but I stuck a piece of cardboard in between the 2 and it still does it. Also when it is making the noise at idle, I can just hold the lower IC pipe and the sound stops?? What the hell??? Please help as this is very annoying and noticeable (it is quite a bit louder in person than in this vid)
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/70c3Ku2X9K0&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/70c3Ku2X9K0&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Ok, I will try that in a bit. Thanks
Anyone else have any other ideas incase that doesn't work?
why people thinks,that 6 bolt can't walk????!!!! i got a crankwalk on my 6bolt right now,and i realized that.### i bent one rod,chew one bearing and my clutch disk keeped breaking and breaking
